plugging in radar
Yes. That's the plug I use for my V1. It's the most convenient as it keeps the cord from having to stretch acoss the passenger compartment to the plug located in the center console. I keep it plugged in and just put the unit on the floor when I'm parked.
Originally Posted by SrfCity
I use the center one for the 8500 so that I can quickly reach over and mute it if necessary. One feature the V1 doesn't have
I am still using the lighter socket under the passenger seat because I have been too lazy to hardwire it, but I'm going to hardwire the V1 into the overhead light.
Originally Posted by jcnesq
Huh? The V1 has a mute button - push the button and it mutes, turn the button and you can turn it off.
MY V1 is in the center, above the dashboard. It is easy to reach the mute button. We have too many of those PIA radar guided speed signs around here.
Following the directions on this site, I hardwired it using a piggyback fuse from AutoZone. It took maybe 10 minutes, including hiding the wire. 2-wire phone cable works perfectly.
Where's the button? The 8500 has it right on the lighter adapter so you don't have to reach up to the unit. If you are using the passenger socket I'd suspect that the V1 doesn't have this feature. Their web site does not indicate that the mute is on the lighter adapter.
This is great. I move my 8500 from car to car, so don't hardwire it. I completely forgot about the outlet on the passenger side (I know,
). This works so much nicer than stretching the cord to the lighter in the center console!
