Unsprung weight - 19 vs 18-inch wheels
Originally Posted by MrBonus
Okay, I've scoured Google for more information with no success. You need to post more details and/or pics. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
Theo
Having the PSM kick in on a public road is quite a feat. I've had my base 997 w/ 18" wheels, PASM and Sport Chrono out for over ten track days now. In sport mode, the PSM does not appear to kick in either when I'm trail braking or using trailing throttle oversteer techniques to get the car to rotate.
The only times it has kicked in was with jerky inputs. Be smooth with your steering and throttle inputs, and the PSM will permit you to get really loose.
Originally Posted by GREEK-TURBO-RACER
Manthey did confirm it is the Le Mans wheel that BBS made for them in 19 inch. Weighing in at 12 kg for each wheel.
Theo
Theo
Originally Posted by Larry Harris
Some of the posts I read on this site are unusual, to be diplomatic. " If I put helium in my tires instead of oxygen can I go 200 mph" "If I can save 4 ounces of unsprung weight will my car handle better?'
There probably aren't a handful of drivers here that can drive a Porsche even to 80% of its potential, including foremost yours truly. Maybe I'm just in a ****ty mood today, and no disrespect is intended, but sometimes I cringe when I read these unrealistic posts.
Gosh darn Larry where were you before I bought the helium
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
