Brake pad imprints
Take the car out and get to an area where you can accelerate and brake repeatedly. Get the car up to 50 or so and then evenly apply the brakes until almost stopped. DO NOT keep you foot on the brake pedal when you are stopped (unless you HAVE to). Repeat several times, inceasing the pressure you apply to the brake pedal. A couple of hard braking applications will complete the break in. Now enjoy the car.
You can also drive the car while applying the barkes lightly while driving. Keep doing this for several miles increasing the pressure to the pedal. The idea is to get the brakes hot and seated without letting the pads sit still against the rotor. No further break in is necessary.
