my 997S brakes squeel/squeek while driving but noise goes away when i press the brake pedal. the dealer checked it and says its normal! the car has 6600 miles and the problem started around 4000 miles.
I have the same issue. I'm at 7000 miles as well. I have yet to get rid of it, but I'm going to re-bed the brakes. That should take care of whatever deposit is catching the pad on the revolution.
Most likely a pad deposit, a really small one, but it's catching the pad on it's revolution and causing that squeak.
Not me, this sound is definitely rotational. You can hear it squeak as the wheel goes around. I think it's the pad sticking to a deposit when the rotor goes 'round.
It gets faster and faster the faster you go, but eventually you go fast enough that you can no longer hear it. The squeak goes away immediately if you apply even the slightest brake pressure.
