Sports Exhaust - have pictures?
When you turn the key clockwise as if to start it up, you can stop short of engaging the starter. Then press the sport button on your console and wait 3 or 4 seconds. Your sport exhaust will then have opened up both pipes on each side and you will get a throaty roar. Its nice to have the option to start up with a low roar (normal) or a full roar (sport)! Either way is glorious, just different.
Yes, you can get it with a C4 or C4s
Originally Posted by littlebigfish
Can you get sports exhaust (XLF) on the 06' 4CS? I don't see it as an option in the .pdf options guide
Porsche is notorious for numerous errors in their written materials, and sadly the PDF is no exception -- despite the fact that they've already updated it once.
So can you enable the sports exhaust to stay on all the time.....or even stop it turning off when you get over 3500 rpm.....my 996 4s had a fuse removed ....Does anyone know if its possible on the 997 C4S ???
Miserable Old Bastard
Yes, there is a way to install the PSE with a separate switch to bypass the cutouts etc and make it stay on all of the time. My dealership is doing the mod for me when they install the PSE for me. My salesman demonstrated it for me on a car in the showroom. My car has sport chrono so I have the sport button and they will be adding a separate exhaust button next to it. The dealership will also add a toggle switch inside the little cubbyhole under the switches. When the toggle is flipped one way, the PSE will stay on at all times, even at startup. When the toggle is flipped the other way, PSE will act normally with all of it's corresponding cutout points and will react normally to the sport exhaust switch and the sport switch. The problem is that the tech has to quite a bit of work to install the switch. I saw him doing another cab and he had the driver's seat out as well as several panels from under the softtop storage area removed.
The other problem is that apparantly there are 6 different versions or part numbers for the PSE switch. My dealership has had to order all 6 of them and the 4 they received are incompatible with my VIN#, they are still waiting for the other 2 switches to arrive. I was rescheduled once already and I have an appt on Mon to get it installed but got a call that I should call before bringing my car to make sure that the other 2 switches arrived.
Royal PITA but I hope it's all worth it.
Ah, from a different post - here's the pics:
1. Before (that's the cable)
2. Pull the tab and disconnect (see the arrow)
3. Leave disconnected as shown.
Works great and leaves PSE on full time from what I've seen and heard on 2 997S (one regular and one with X51 power upgrade).
