Porsche Battery Maximizer & Switched Cig Lighter Confusion
Still plays with cars.
The maintainer is not really a charger. It is designed to offset the drain of "always on electronics" which will drain the battery in two weeks or so. It can very slowly charge a battery but as observed it takes forever. I would not hesitate to use it in any outlet since the current delivered is very low.
Rgds,
Rgds,
Question.. When you guys refer to the center console cig lighter outlet, is that the one actually in the ash tray compartment? or one of the other 12V ones. With my 04CTT, i had stupidly ordered the non-smoker pkg, and lost the 12V cig lighter outlet. I always put the Charge-O-Mat I in the 12V outlet in the rear seat console section. Would using the 12V outlet in the footwell of my C2S screw up a Charge-O-Mat II or not properly charge??
![surrender](https://rennlist.com/forums/graemlins/surrender.gif)
I don't think it makes any difference where you plug the charger into. You do need to find out from the dealer which outlet you should use to plug the air compressor into though. It's been reported that if you plug the compressor into any outlet other then the cig. lighter outlet it will blow the circuit fuse.
Rgds,
Rgds,
