Torque Wrench Recommendation?
Originally Posted by uzj100
Yep, Snap-On all the way. I've got 4 of them, including inch pound. Probably one of the most handy is a swivle head 3/8 5-75ft lbs in half pound increments. These are things you buy only once
They sure seem simple and easy to use! ... At 400 bucks a pop, they better be!
Anybody here using a digital torque wrench they'd like to offer feedback on?
Ben: the ones I have are:
QJR217C- 40-100 in lbs
QJFR275C - 5-75ibs (.5 lb increments)
TQFR100B-20-120 lbs (2 lbs increments)
TQFR250C-50-250 lbs (5 lbs increments)
None of these are the digital type. I think you'd probably get the most use out of the 5-75 lbs one and the 50-250 lbs one. The 100B is 3/8" drive, the 250C 1/2" drive.
Not sure if they are any more accurate than the standard ones. Either way you go, I think you'll be very happy with anything Snap-On.
For as long as I remember, Crapsman torque wrenches were never considered hand tools, so no lifetime warranty. (I don't know what you would consider them.) I think they only have a 1 or 2 year warranty. Last I got was a Husky which seems of marginal quality, but at least has a lifetime warranty. This thread over on PPBB is good. Apparently, Snap-On ditched the sub-contracting of torque wrenches with Precision Instruments, and now Precision Instruments sells them under their own name.
http://www.ppbb.com/scgi-bin/boards/...l?read=1155645
Technical Guru
Originally Posted by OCBen
I'm just wondering how good they would be and how long they would hold up in terms of accuracy.
Originally Posted by Crazy Canuck
I have a snap on torque wrench with the adjustment via a little **** on the side. Very good tool.
Interesting note on Precision Instruments. If I were in need of a new torque wrench, I'd sure consider one of the Tech type, tho for not much more than the $400, you can get two wrenches. But, need is seldom part of the equation when talking about things like this (Read: I'll probably track down the Snap-On man tomorrow!)
