Track Tire Pressures
What tire pressures are you guys running at the track? I will be in Sebring on Sunday and want to be prepared.
Thanks in advance.
Thanks in advance.
Still plays with cars.
What kind of tires? If streets (the tires the car came with - I am guessing that's what you have) aim for 40 lbs hot. Start with lower cold pressures say 33 or so and check pressures every time you come in from a session. Bleed down to 40 hot, yes, all 4 tires the same. If you are just starting out and going more slowly, you may have to add air, if so add 1 lb of cold air for every 2 lbs of hot pressure yoou want, i.e., if you are are 36 hot, add 2 lbs of cold air. DO NOT run the factory pressures, your tires will overinflate due to heat build up!
Regards,
Regards,
Regards,
Regards,
