Gremlins: Parking lights on but not SFRTW club yet
![Angry](https://rennlist.com/forums/images/icons/icon8.gif)
I had the Carrera out yesterday. It sat in the rain for about 90 minutes (light rain, not heavy enough to need an umbrella but enough to get the car wet). Threw some stuff in the trunk and had it open for about a minute. Drove home with one stop without event. Parked in the garage and the parking lights came on and would not turn off. Tried the light switch, the ignition switch, restart, threats - lights still on.
NO System Fault Return To Workshop but chirping alerts that the parking lights were on. I went and messed around elsewhere for 15 minutes and came back to find the parking lights still on. Switched ignition on but did not start car and they went out.
Car was well behaved today. I will dutifully record the problem with the dealership when I have the oil changed post break-in next week. Other than the cd player intermittently forgetting what track it was on when shut off the car had been flawless up to this point.
Milage 2038. February build with extra port hold before going on vessel.
Greg
2005 Carrera S Coupe, Lapis Blue Metallic, Carrera Classic Wheels, PCCB, Bose, Sport Shifter, Sport Seats
Greg
I've had similar gremlins. Open the passenger door and the parking lights came on. That happened once or twice and never happened again. Also had the interior lights stay on for a long time and would only go out when I locked the car. That issue also stopped on its own.
AeroSmith: My problem is most likely related to that mentioned in the link you provided, but I did not get the System Fault, Return To Workshop message.
rss997: They are not set to stay on at all. The light switch was in the off position when it happened and it did not function as the lights do in the “delay” position (I forget the correct terminology for the first notch to the right of off). Also, when the parking and fog lights stay on when the light switch is in the “delay” position, the chime has not sounded.
Up until Saturday, I had managed to avoid opening the trunk when it was wet and had not had any problems other than the intermittently schizophrenic cd player. While I will mention it the next time the car is in so it is in the record book, I am pleased that I am not in the SFRTW club.
Greg
Greg
mine sat in the pouring heavy rain yesterday afternoon for hours...I mean serious downfall (we havent gotten this much rain in Boston for a long time) started her up right after no problem no gremlins...
Greg
Greg
I have found that occasional electrical issues can be resolved by "rebooting" the system by turning the ignition OFF and removing the key, then re-inserting the key and re-starting the car. Do you think Microsoft had any invovlement in the design of the lectrical system?
So funny, but so true. Reboot fixed my single-cd issue, but only for a while...it came right back after about 24 hrs.
I also had my PCM lock up on me the other day, that was very interesting. Cycling the power on the car was the only remedy.
My PCM was replaced when it began showing daylight and nighttime versions of the Navi map at alternating intervals for no apparent reason. Just recently I had the Navi DVD player and DVD replaced when it began losing 1/2 map images and then finally locked up and would not recognize the DVD's presence at all.
I had the Carrera in for its post-break-in oil change today and had them check on the parking lights staying on problem. Diagnostics said everything was ok. No error codes were recorded in the computer. The service manager dutifully recorded the problem in the car’s permanent record.
Must be a Windows 98 operating system.
Greg
![nono](https://rennlist.com/forums/graemlins/nono.gif)
Greg
I had the same problem with the parking lights one time last week.
During the day, opened up the door after shutting down the engine, and the parking lights on notice started up. Turned the lights on, then off with no resolution.
Restarted the car, turned it off, and it resolved.
I still haven't returned my car to the dealer to fix my hood latch problem... yes I will return to workshop soon.... and I will mention the parking light problem to them when I do.
i have had the rtws 2nd time ...one from heavy rain the other from my little girl helping me wash the car... both times showed up the day after really wet.
2nd time i was towing my vehicle from the track
kind of a pain in the A ...just to have to go to dealer. i wish they could fix this
