So I get around to checking out the Mini Coopers...
Well the mini doors actually do sound solid when closing but windows feel loose and the rear hatch has it's rattles especially on bumps and I got some sorta squeak on my seat. Also sit down and lean on the mini door with your back and see how solid it is. Other then that it's a great car for the dough but change those brick tires(run flats)-they suck bigtime. Handles pretty well/decent gas mileage easy to park. Regards. Mike
.org
<Well the mini doors actually do sound solid when closing but windows feel loose and the rear hatch has it's rattles especially on bumps and I got some sorta squeak on my seat.>
the dealer has a repair kit for the hatch that fixes the problem, under warantee
the seats do squeak, but I think that is just to remind you it's a British car...better that than lucas parts
Lol-actaully squeaks don't bother me. Only cars that ride like a boat does : ). I've been thinking about pulley/header/cat bypass and intake-what's good out there with after market guys? Regards. Mike
.org
check out Alta for the intake kit . The intake absolutely makes power as does the reduced pulley.
I figure on having 195 or so hp based on dyno tests I've seen on similarly modded cars.
The lighter wheels and 16" tires also dramaticly changed the performance curve. the h&r sport springs lower the car and improve the cornering ability
I went for a borla exhaust after i was rear ended and needed a new exhaust, but it didn't make a lick of difference in performance.
my first mod was the alta mini antenna..eliminates the radio controlled toy car look.
there are a ton of shops and manufacturers offering pretty much the same mods, but check out these :
http://www.altaminiperformance.com
I'm in philly, and these guys are local to me and do great work, and have a large east coast following
http://www.helix13.com
perry
perry
I looked into Promini as well as far as intakes go but would you say ALTA intake is the better one or all the same. Also Promini has a 19 % pulley versus 15% from ALTA(unless that changed). NE issues just using springs itself or you gotta do shocks too(a little lower would look nice). Actually I don't mind the antenna. I'm trying to put it on front of hood so it's really remote control look : ). Mike
.org
nice part about the mini, just springs alone will lower without need for shocks or even a realignment.
I did my mods about 2 years ago and at that time the alta was the only intake.
there is not too much to it, basicly a foam filter and some bent metal w/a bracket to hold the computer box. seems like more than a few copycats have shown up
my pulley is a 17%.there is a 15 and a 19 %.
best bet for up to date info is to call some of these vendors and check on the mini boards
perry
perry
I had a mini S for 8 months then sold it and a month later bot the 996. It was a fun car and prolly got more looks in it than the current car. Its alot of bang for the buck--
Mike
Mike
.org
Get one you'll enjoy it. Definitely a good commuter car and occasional trackday sessions. I had to get one just due to the fact San Francisco roads suck and my GT3 was my daily driver-no fun driving in the city(bumpity bump in an off roading way). Regards. Mike PS-MrBonus-GT Silver is a great color : ). Thanks for the links Perry-I'll check them out : ).
