How to Wash/Maintain 997 s Cab Canvas Top?
This may sound like a silly question but does anyone have any advice or prior experience in maintaining the canvas top of a cabriolet? I'll be getting my cab s next week and I've been getting mixed reviews on how to treat the top (ex: with scotch guard). I live in SoCal and I'd like to know if i should take extra care in pretreating and protecting it from the sun.
use either raggtop or porsche top cleaner and spray protectant. Porsche cleaner an protectant is avilable at dealer. Raggtop can be found on internet. I usea car cover to protect it also.
On a Boxster I had I would try to refrain from cleaning the top too often. If you wash it yourself it's easy to not get it wet with the hose. As long as the car does not stay in the direct sunlight all day I personally would not worry about treating it. Let us know what you find out?
I use lint roller to pickup dirty and lint on the top. Rinse it with water every wash or every other wash. Use a top cleaner 2-3x a year or more often if it's dirty. Use a soft brush to get dirt out.
The protectant is good as tops are usually black and attract lots of heat. It protects it from sun and repells water, moisture, and dirt from getting into the canvas.
djantilive seems to have covered it well....Here's a how to from Autopia (which is definately the premier detailing forum on the web)
http://autopia.org/kb/index.php?page..._v2&id=29&c=21
Jason
Jason
One thing I try to avoid is rubbing the canvas back and forth with a brush.
I more or less let the bristles contact it and move the handle in a circular direction slightly to get the bristles to "dig" into the fabric to loosendirt. Then I pick up brush and move it to the next small section.
Rubbing back and forth puts alot of wear on the uppermost threads of the fabric weave. When you do it this way it's like you're sanding the top of the fabric and leaving the dirt down inside it.
