Quick Question on Window Operation
Old Apr 22, 2005 | 02:03 PM
Balloonmeister's Avatar
Balloonmeister
Default Quick Question on Window Operation
I know I could RTFM, but the car's in the shop for the infamous System Fault message and it occured to me that when I hit the up button for the passenger window, unless the window is about half way up already, the window will not automatically raise to its full up position. I.e., if the window were fully open and I pushed the button to the full up position, the window will move up as long as I have my finger on the button. When I let it go, the window stops. If the window is more than half closed, it will close the rest of the way with a quick jab to the full up position on the button. The driver's window seems to work fine. Anyone else notice a difference in the operation of their automatic up button position on their passenger window? TIA.
Old Apr 22, 2005 | 02:24 PM
CO997's Avatar
CO997
Yea that's just how the window works. Not sure what the reason is. The passenger window will only go up once it is past half way. I find it kind of annoying. I'm sure someone here knows the reason for it. At least it goes down all the way with one touch.
Old Apr 22, 2005 | 02:32 PM
cmoss
Guest
Posts: n/a
for what it's worth the windows on my honda function the same way.
Old Apr 22, 2005 | 04:13 PM
Balloonmeister
Thanx FL997 and cmoss. Now can someone plz explain this logic to me? I'm at a lost to understand this one.
Old Apr 22, 2005 | 04:45 PM
Paul523's Avatar
Paul523
It 's gotta be a safety thing.
I read a few months back of a number of toddlers have been tragically pinched
when hanging out the window of a parked car with keys in ignition from
inadvertently pushing auto-window up control.
I can't imagine what parent would leave their child unbelted AND unattended with the keys in ignition.
wondering does it behave the same way when your passenger uses the window lift on the passenger side?
Old Apr 22, 2005 | 05:31 PM
19_hole's Avatar
19_hole
It is a safety thing. TUV, the safety group in Germany is pretty funny about some of it's requirements.
Old Apr 22, 2005 | 09:36 PM
jboyko's Avatar
jboyko
Dumb *** car. I bitched about this problem twice until they finally said "that's the way it is". Why bother to have an automatic up, for the last 4 inches.
That part probably cost me $ 300.00. I can get better automatic up value with Viagra.
jb
Old Apr 22, 2005 | 09:57 PM
jnx's Avatar
jnx
I agree it's a pain, But it's interesting that I had a new Boxster S as a loaner, and the passenger side works one touch up, and down from any window position. So is that to say the Boxster is not as safe as the 997?
Old Apr 23, 2005 | 12:57 AM
Speed's Avatar
Speed
This has to be the reason. The passenger window in the 996 has the express raise feature but the button is on the center console where, presumably, a child hanging out the window can't operate it. The buttons on the 997 are on the door and I guess a kid could operate the window while his head is sticking out.
My question is why Porsche did away with the ability to raise and lower the cabriolet top with the key in the door. I find that really convenient on my 996 when I have packages I'm going to dump in the back seat and I don't have to futz with opening the car, moving the front seat, getting in and then lowering the top.
Old Apr 23, 2005 | 10:09 AM
rss997's Avatar
rss997
almost as bad as the f ing seat belt alarm that gets louder..........
Old Apr 18, 2006 | 05:25 PM
M A Z N G's Avatar
M A Z N G
Safety
Old Apr 21, 2006 | 02:47 AM
Nicolaasdb's Avatar
Nicolaasdb
safety ??? why don't they make the windows pressure sensitive??
Old Apr 21, 2006 | 10:09 AM
allegretto's Avatar
allegretto
After I read this I went out ot my car and checked. My windows in the front are fine and raise and lower the way I would expect. There is no halt from any position. My rears are manual however.
Is this a Cab vs Coupe thing or do you all notice it with Cabs too?
I'll check my build date this afternoon, maybe it has been changed recently.
Old Apr 21, 2006 | 10:21 AM
OCBen's Avatar
OCBen
Huh? .. You mean you've got crank handles for lowering the rear windows???
Old Apr 21, 2006 | 10:47 AM
allegretto's Avatar
allegretto
Yeah, and I've gotta kick start the motor too.
What...???
What I mean, my OC antagonist is that I must keep the buttons pressed to continue motion for the rears, but not for the fronts.
I think it's just the So Cal Porsches that get the extra safety devices, broader learning curves out there.
