View Poll Results: Under what circumstance did your System Fault occur?
Voters: 16. You may not vote on this poll
How did your System Fault occur?
It would be very interesting to see how many people with the System Fault have had this happen after washing and/or waxing their car.
After I finished drying the car, I didn't drive it until the next day. I turned the ignition on to check the oil, and the System Fault appeared. I made an appointment with the dealer, they reset the system, Fault has not returned. That was 1 week, about 300 miles, and 2 washes ago. I am afraid it will return at any time.
Originally Posted by Pete@Stratmosphere
Washed on the 9th. Waxed on the 16th. Error on the 16th. -Pete
Well, I washed and dried the car with the hood closed, then I Zaino'd the car, then I wiped down the plastic inside the trunk and engine compartment with a damp chamois. I then went to check oil level and BLAMMO. I had NEVER checked the oil level just after a wash before.... hmmmmmmmm
I have washed it MANY times before, both at the car wash with high pressure and by hand. I have opened up the trunk while it was still wet before also....
