Homelink programming problems?
Anyone else who's had trouble programming the homelink buttons? Can't seem to get mine to accept a Craftsman garage door opener code. I've tried the directions for both the fixed code and the rolling code, but no go. Interestingly, when holding the garage door remote, the fog lights would flash, which is supposed to mean the buttons accepted the program.
Tips, suggestions welcome.
YoungTurk
'05 Carrera (Arctic Silver/Black)
YoungTurk
YoungTurk
YoungTurk
Try it!
srb1194 (08-03-2023)
Same exact thing happened with mine. What I did was hold the homlink button down until it started to blink. Then I held down the red program button on my garage door opener. My garage door opener blinked twice as usually to say it was in program mode. Then I held down the homelink button for about 5 seconds and the garage door opener blinked again say it accepted it. From there on out it has worked just fine. Hope this helps.
Okay - called Homelink Tech Support (Thanks Robert) and got it to work. Here's what i did:
1) Press and hold buttons 1 & 3 (2 outside buttons).
2) Release when small amber light next to buttons flashes rapidly.
3) Press and release button you wish to program. Amber light should flash slowly, about once every second.
4) Take your remote to the front of the car, as described in the 911 owners' manual, and press and hold button until fog lights flash 3 times.
5) Go back inside car and verify that the amber light is neither flashing nor solid.
6) Press and release the "learn" or "smart" button on the garage door opener. Important - don't press and hold, just press and release. There should be a light just above and smart button and it should light up and stay lit solid.
7) Go back to the 911 and press and hold for about 3 seconds the button you're trying to program. You may need to do that about 2 or 3 times.
The button should then open/close your garage door - it did for mine.
YoungTurk
Xenons
19" Carrera S wheels
Nav
Bose
CD changer
Heated seats
Power seat package
Sport steering wheel
Thna
YoungTurk
Xenons
Nav
Bose
CD changer
Heated seats
Power seat package
Thna
The following 3 users liked this post by Patriot:
Young Turk, congrats man - Mine still does not work with my Genie Max Pro garage door opener. The Genie dealer says its the remote but we tried a different type of remote and it still did not help.. Can't call Home Link support as I'm not in the states and I dont think they'll support anyone outside the states.
Just follow the steps outlined in the owner's manual - I've done it on 3-997.1's and 1-997.2 - worked every time.
Turk, support's instructions worked perfectly for me with one minor exception. After programming the car (Step#5), I had my wife briefly hold the button in the car while I simultaneously pushed the button on the back of my opener. They seemed to sync instantly.
Edgy01 (04-03-2022)
I've done some research and the reason 997.1 (and likely 997.2) cars cannot work with modern liftmaster and chamberlain openers is because they have a new rolling code system called Security+2.0 (all 997s only work with Security+). The 2.0 standard was released on 8/2012. It's easy to find out which your home uses by looking at the learn button on your opener motor unit. All security+2.0 openers use a yellow learn button. Our cars only work with the older orange and purple button openers.
I do have a solution that I successfully installed today. You simply need to purchase a homelink module off of a more modern Porsche (and probably Audi/VW though I am not positive). I noticed the pinout on the modules are identical and the sizes are as well. The units go for between $25-$50 on eBay. If you do go this route, simply buy one for a car (doesn't have to be a 911) made after 2017 or so just to be safe. I bought one off a 2018 Macan and after connecting it up, I was able to get the car programmed in 10 seconds. Worked like a charm on my very new Liftmaster opener.
Liftmaster Info:
https://www.garaga.com/information/f...master-offered
Homelink module I purchased (sorry it's an eBay link so this will expire)
https://www.ebay.com/itm/155288432638
The install required removing my front right wheel, undoing the left side of bumper cover (sorry should've said passenger/right side), and replacing module which is simply clipped into a bracket. IMO, this beats using one of those repeater kits because those essentially erase all the security measures and makes your garage opener susceptible to very simple attacks. The range on those is also TERRIBLE. I had another old car that I used one of those with and it simply did not work until your car was right in front of the garage door. I also love super clean and proper fixes, not workarounds.
Liftmaster Info:
The following 5 users liked this post by funnelofdoom:
emjohn43 (09-07-2023),
Evan2023 (Yesterday),
fourthirteen (08-01-2023),
LucV (08-02-2023),
SpectreH (08-01-2023)
Liftmaster Info:
The install required removing my front right wheel, undoing the left side of bumper cover, and replacing module which is simply clipped into a bracket. IMO, this beats using one of those repeater kits because those essentially erase all the security measures and makes your garage opener susceptible to very simple attacks. The range on those is also TERRIBLE. I had another old car that I used one of those with and it simply did not work until your car was right in front of the garage door. I also love super clean and proper fixes, not workarounds.
Liftmaster Info:
Thanks for the follow-up. I've tried using the repeater kit but couldn't get it to work.
