Warning about gas quality
Thought I would use a new gas station for my Pcar on Monday...same brand( Amoco), just different location. Monday evening, got into the car and started it--all hell broke loose--the car bucked, smoked and the "check engine-visit workshop" light came on under the digital speedometer. I shut it down after about 15 seconds of this and called the dealer. Service manager said that this "check engine" warning has to do with the emmissions regulatory portion of the computer and that it should 'self correct' itself in a couple of days. He asked me if I forgot to screw the gas cap tightly--I said that I always make it a point to close it until I hear 3-4 clicks.
I suspected that I got a bad batch of gas at this station that I had never been to before. Two days went by--rough idle, but otherwise no major problems. I stopped by the dealer to have them check out my baby...their computer said "misfire" codes came up, indicating poor quality and/or low octane gasoline. The pump I was using said 93 octane, but who really knows what the hell was going into the car?! I do know not to fill up if you see a tanker truck filling the main tanks at the gas station...due to churning up water from the bottom of the holding tanks, but how are you supposed to know about the quality of the gas you are getting other than sticking to a particular brand.
Well, all is right again with the car. The light has not reappeared and I am happy once again. Just a warning...our 997's are very particular with gas quality...
If I am going to use a different brand then I try to buy from a higher volume station. Thanks for the heads up.
