Should I replace alternator
2008 base Carrera Cab 6MT 107k miles
What would you do?
I broke and therefore am replacing the oil filler tube (thank-you Bruce for great DIY) and so have the alternator out. I’m pretty sure I’ve found and deciphered the build date code and it is the original alternator (same build month/year as the car). Spindle spins freely and silently, and I have not had any alternator-warning signs or lights. I do pit the battery on a tender if I will not be driving for a few days. I have no reason to suspect the alternator will fail anytime soon, but at 18+ years old and 107k miles, I wonder how well it is working
There is no reputable alternator refurbish shop anywhere close to where I live. I can get a new one for around $470. The cost is in the “I dunno” zone for me: if it was much more, I would definitely pass and re-install the old one. If it was much less, I would definitely put in a new while I have the chance. Same with work effort.
Would appreciate learning which way you would go. Thanks.
What would you do?
2009 C2S 208K miles
Mine is fine. If you are getting a code, low voltage, or squealing/grinding noise, the yes, it is bad. Otherwise... changing it out just because of age, well, there are plenty of other things on your engine that are way more failure-prone than the alternator.
Peace
Bruce in Philly (now Atlanta)
Peace
I replaced mine and it had 72,000 miles on it. It appeared fine but was barely outputting 12V so made a decision to swap it as a "while you're in there" thing.
No biggie as it's certainly not the least accessible thing but I'd see if you can get a mechanic to check output on it.
Another thing you can do is relieve it of the belt and spin it free hand (or even throw a socket on an impact and spin it up).....and see if it makes any unfavorable sounds....(grumbling of bearings, whining, etc.)
Both output & mechanical stability are worthwhile reasons for replacement, but if both are good, I'd keep running it!
(I had a 1998 Toyota Camry that had almost 300,000 miles on it and its alternator was still good....but that's Japan....I don't expect that kind of quality out of the German folks)
My car has 32K miles on it. The alternator failed recently.
Bruce makes a lot of sense; however, you already have the old one out... I personally don't like disturbing things multiple times.
Originally Posted by 8x57IRS;[url=tel:20426526
20426526[/url]]So if I had some time, I would clean it and at least check or replace the wear parts. Usually, these are the carbon brushes and diodes. There are lots of videos on this; it's not very difficult.
this is exactly what I did when I was replacing the AOS, no issues with alternator but when I pulled it apart found that brushes were over half worn at 100k miles, diode pack replaced for peace of mind. Bearings spun well so left it at that.
Where did you source the brushes and diodes from?
