Trunk Tool Foam Removal?
Old Feb 24, 2025 | 06:29 PM
00 Scrub's Avatar
00 Scrub
Default Trunk Tool Foam Removal?
Anyone got any tips or guides on how to remove the tool foam from the trunk? I've got most of the trunk stripped, but it appears the foam is glued down somehow. I was hoping to remove it without breaking it so I can put it back in after I'm done.
Old Feb 25, 2025 | 01:53 PM
campbesl's Avatar
campbesl
Have you tried sawing it off with dental floss, fishing line (braided would work best) or a chain saw?
Old Feb 26, 2025 | 05:14 PM
VAG Lover's Avatar
VAG Lover
I was going to suggest the same thing. As a biker I would try a shift cable. Hold it as low as possible and start sawing the bottom few mm off the foam block.
Old Feb 26, 2025 | 10:56 PM
00 Scrub's Avatar
00 Scrub
Thanks. Those sound like good ideas. I'll give the bike cable/floss a shot.
Old Feb 27, 2025 | 01:24 AM
jayzbird's Avatar
jayzbird
An oscillating multi-tool would make quick work to separate the foam.
