PSM/Pasm failure (not battery)
Old Dec 21, 2024 | 06:40 PM
Bradenvlp's Avatar
Bradenvlp
3rd Gear
Default PSM/Pasm failure (not battery)
Hi - hoping to ask for some ideas. 997.1 Coupe 4S. I installed PCCM+ a few weeks ago and all was great… until I really screwed up.
I decided to remove the CD changer from the frunk. I got the fiber cable out easily but could not get the wire harness out. Very tight, no play, couldn’t see clip…. So I decided to cut the 3 wires. Ugh. While tying everything up, in real fup moment, I touched hot wire to my Bose Amp. It started cutting out and then went full no sound. Fried.
Worse. I have PSM, PASM failure and steering sensor connectivity codes that won’t clear through driving routine or scanner. All fuses ok.
PCCM plus all behaving normally except no sound (I can hear some noise from sub).
so….
i have patched back in CD changer. No change.
I have a new to me amp coming from eBay and will install.
assuming that doesn’t fix anything, what would you make your next step? I can eventually take to a pro but mine are closed for holiday and this is my daily and I have lots of driving planned. So rental car…
Old Dec 22, 2024 | 02:26 PM
Bradenvlp's Avatar
Bradenvlp
3rd Gear
Sorry for the duplicate thread. I’m new and didn’t realize the moderators review posts before releasing.
Old Dec 30, 2024 | 08:34 PM
997_flo's Avatar
997_flo
I've seen the PASM light come up on my dash before and it always goes away after driving a little bit. Try that first before spending money.
