Recaro Pole Position in Sea Blue - lots of blue!
Jeroen//997 (08-14-2024)
An update regarding the belt buckle receptacles for people installing PP´s in the future and end up here.
There is a lot of info online and on RL, and some is contradicting. You´ll need 2 pcs 997 803 183 11. The is the passenger side receptacle for the folding buckets.
I used two of those as they are longer than the driver side one. (997 803 183 10, which is for some reason 0,5 inch shorter) There is no issue using a passenger side item on driver side, they are the same.
Cheers
Regular vs the new receptacle
Cheers
Graufuchs (08-22-2024)
The following 2 users liked this post by 63mercedes:
Jeroen//997 (08-23-2024),
soundbehindyou (08-22-2024)
TommyV44 (08-24-2024)
