Checking wheel size
Checking wheel size
Wanting to confirm wheel size for my 997.2 C2S as I’m considering a change.
Wouldn’t this fit a narrow body?
Front Wheel Specs: 19"x8", 45 offset and 5x130 bolt pattern
Rear Wheel Specs: 19"x11", 55 offset and 5x130 bolt pattern
Thanks in advance!
Thanks in advance!
I have found this to be the best site for checking Wheels, Tires & Offset:
https://www.willtheyfit.com/
Herr Motorspiele (08-05-2024)
they’ll be fine, just make sure you go with 295 section tyres on the rear. 235 fronts.
Yes, will fit no problem. Should be pretty close to flush to fenders.
305 rears will work without rubbing. I am running a 19x11 with a 51mm ET with 305 tires rear with no issues.
