Is there an easy way to disable the heater core
Brothers/sisters, living in the tropics, there is no need for the heater in our cars year round... in fact maximum cooling is what is needed most of the time... I am wondering if there is an easy way to disable the heater core so that no hot water goes into the cabin anymore and cooling is simply regulated by the throttling of.capacity by the variable compressor... ideas and experiences??
In looking at the diagram below, you may be able to put a U pipe a bit lower from the heater core... I don't know you would have to just start taking things apart and figure it out. This does not look like a difficult job at all. You will need to keep a seal at the top of the heater core, or your fan will blow air out into your front trunk.
Peace
Bruce in Philly (now Atlanta)
Number 4 is the top of the heater core and is located behind your battery.
![](https://cimg6.ibsrv.net/gimg/rennlist.com-vbulletin/1046x1006/hcore_762988667832a5dc9a12a35489025bf4b4c14d5e.png)
i will look into this.. thanks Bruce! it should not be a difficult job, by the looks of it. the next question is will this mod affect in anyway how the ac control system of our cars work??
High temperatures can be "tolerable" once you reduce the humidity to low 60%, which my A/C seems to do quite well. Yes, it does take a little while when you first turn it on but you can quickly see the resulting water coming out of the A/C drain hose.
Mind you at home my garage is open all around but the very high ceiling provides constant shade. Also, when I go anywhere I either park in covered lots or seek areas shaded by trees.
Anyway and getting back to your question/request, I'm not sure how much or how quickly that by-pass will contribute to more or better cooling but it is an interesting question.
Yes the 997.2 ac copes well enough with the high temps of asia.. but thinking it would be better still if it did not need to cope with the extra heat from the heater core..
