Convertible top rocker switch rattle....
![](https://cimg8.ibsrv.net/gimg/rennlist.com-vbulletin/426x393/rocker_switch_4acaaeea2d06c0da2db668e5be3a4b7e7249fd98.jpg)
I wanted to post this because it was one of those nagging issues that you can never solve- a rattle or vibration... After many YEARS of listening to this vibration/rattle, I finally figured out what it was. I have a 2010 997.2 C4S Cab, and the rocker switch that operates the top sits in the center console, between the handbrake and the ash tray. I have had this tinny- rattle/vibration, like spare change sitting in a glass bowl, for years while driving down the highway. If I held my hand over the entire center console, it would go away. I tried removing the ash tray, removing the cigarette lighter, taping the lighter, and then my best one yet- pushing a bicycle innertube into the center console space below the ash tray and inflating it a bit to muffle the vibration... yet it continued. I got to where I was driving w my hand covering the console to minimize this. Then one day, about a week ago, I happened to rest my finger in the back of the rocker switch.. and the vibration stopped. Huh? You've got to be kidding me. That was it. That dang switch was apparently loose enough over all this time it was telescoping the rattle thru the entire center console. The switch works fine, but there must be a small component that has worn enough to rattle. Solution #1: replace the switch. https://www.pelicanparts.com/More_In...3517&DID=16483. Not sure how to remove it. The pix show a clip at one end, and I don't want to try to dig it out. Theoretically, you can access the clip by pulling up on the handbrake which allows a space to appear below the switch. You could try to run a flat screwdriver up there to push the clip up, thus releasing the switch. Removing the console is not an option. Solution #2: Place a small black piece of foam in the finger space on each side of the rocker switch. This worked. Vibration gone, and the soft foam allows use of the switch when needed. If anyone knows how to remove this switch that would be helpful. Otherwise- foam it is. I hope this solution saves the sanity of at least one person anyway..
My 2011 does the exact same thing. I found the culprit a lot earlier than you and have been living with it for 3 years , https://rennlist.com/forums/997-foru...ch-rattle.html . As you can see there were no replies, I hope you have better luck. Subscribed
