Window “sweep” replacement
Old Dec 11, 2023 | 01:13 AM
chrispe's Avatar
chrispe
Default Window “sweep” replacement
Hi there,
on my 997.2 all the seal/sweeps on the windows (convertible) are starting to deteriorate
I have attached a picture, does anyone have guidance how to change those and how involved it is? It’s not only those between window and window but also those there the window slides into the body.
Appreciate
it,
chris
Old Dec 11, 2023 | 07:32 AM
sburke91's Avatar
sburke91
The ones between the front and rear window are pretty easy. This video has a pretty good overview of how to do it:
Not sure yet on the rest, but will know more later this winter, a I need to replace mine too.
Old Dec 11, 2023 | 10:04 PM
chrispe's Avatar
chrispe
Thank you @sburke91 , appreciate it!
Would be great if you can share some insights for the outer seal (?) one, once you got to it?
I believe the inner seals are probably part # 996-543-177-01, does that make sense?
