DAB Aerial Components from PCCM+
Several years back, I fitted a Pioneer head unit to replace the old PCM 2.1 in my 997 TT. It works very well, but DAB reception has always been tricky - i have a DAB whip aerial I installed behind the trim on the a pillar on the passenger side. I'm trying to find out if it's possible to get the components from PCCM+ to enable you to use the built in aerial in the same way that PCCM does - splitter, bypass cables etc.. I've seen some things about the components for 996, but can't find anything useful on 997. Has anyone done this?
Ta
pete S
Ta
pete S
