'09 C4S - Do I need to reprogram my winter wheels/tires?
I bought a set of lightly used winter wheels and tires second hand. Do these need to be programmed to my car when I mount them?
If they have TPMS sensors that are compatible with the car, then you should be fine. If they don't have TPMS, then you'd need to program out the TPMS or deal with the light on the car.
jbkusa (11-25-2023)
Yeah, I just did that on my 2009 4S cab. just go into the tire pressure menu and change from summer to winter tires after they are mounted on the car . You will get a warning message and red exclamation mark until you make the change in the menu. It's on the same stalk where you check oil level ( short one on the left below turn signal stalk).
