Putting car on lift
Putting car on lift
I literally just heard of hockey pucks for my 997.... I've been using a 2 post lift for most of my work with built-in rubber pads, and it seems like it's been fine. I haven't noticed any issues and it seems like it lifts super normally with no bending or touching of anything it shouldn't (anything besides the jack points) -- should I be concerned? Should I buy four Porsche hockey pucks? They seem pricey for something that seemingly doesn't help me at all. The only thing I think it might help would be if I need to remove some of the liner underneath, it might make it easier to get to a couple of the screws.
carguy999 (11-05-2023)
2009 C2S 193K miles
I don't know why you would need them, you have rubber pads. That is the point of the hockey puck, it is to put rubber between two metal parts. Not all jacks have rubber pads and if you put metal on metal... bad things will happen.. they will slip.
Peace
Bruce in Philly (now Atlanta)
Peace
Thanks Bruce, wanted to make sure I wasn't going to give myself bore scoring doing this wrong 🤣
dmpslc (11-06-2023)
Place the rubber pads so they just reach the inner part of the jacking points and you'll be able to remove the panels with no troubles.
As Bruce said, as long as you have rubber on metal you are fine. Just never have metal on metal.
