Rear window not going up and down
Hi guys! Had a leak in the car, i think from rear quarter window not being fully up after battery ran out and it didnt close up properly after opening n closing door with no power. (What a wally)
how can i check its not the fuse? On the fuse diagram it only gives me a fuse for the driver front window motor 🤯
if its not the fuse apparently i can swap the relays to test? Where do i find this please? 😬
next im guessing remove drivers door panel and swap the switches.. eek
if that doesnt work
finally i need to remove the reAr quarter door panel and che k the regulator and motor.
any commemts or pointers hugely appreciated! Thankyou
if that doesnt work
