8704 Door h. button inner sh. stroke - 997 not locking double beep
5th Gear
Hi Everybody.
I need your help. The durametric tool is showing me a code 8704.
Fault: 8007: Door h. button, inner sh. stroke . Left Door Module
Symptom: Remote will not lock doors (double beep). Key not locking doors (double beep). The radio not turning off.
I have already checked the PAS computer. I changed the locks; Window going down a little before opening the door from outside. Window is also lowering from the inside ( note that it is not going down as much as when I do it outside ); I am deducting that both microswitches are working.
Any ideas? Please help
Thank you!
Thank you!
