997.2 factory sports suspension guru?
Old 07-04-2023 | 09:30 PM
cgfen's Avatar
cgfen
good information, thanks for the ongoing discussion.
ride quality sucks = harsh, minimal damping, much worse than my 996 GT3. Unacceptably bad now in 2023, not sure if I thought the same when we got it in 2009.
Be well.
stiles_s (07-05-2023)
Old 07-04-2023 | 09:46 PM
waterpanda's Avatar
waterpanda
2009 C2S ~65k miles + Eibach lowering springs + PASM + DSC controller
Had a clunk coming from the front left for a while now... it's gotten bad to the point I hear it every time I hit bumps < 45mph. Then like a week later, after some rough cross-Bronx NYC roads, the front right started squeaking like hell when turning the steering wheel to the right. Tried the grease the stack by the top mount to no avail.
I'm a big hobby DIY mechanic guy, but will leave chasing suspension issues to the professionals. So I take it to a local speed shop, the mechanic tells me the shocks and top mounts are on their way out. But I changed the top mounts (Lemforder from FCP) while installing Eibach springs 1500 miles ago. Apparently, the lowering springs can exacerbate any underlying conditions and accelerate wear. Not something I wasn't aware of, but didn't realize to which extent.
Anywho, the car is getting dropped off tomorrow to get a fresh set of B8s installed and the top mount will be inspected for wear / replaced. Report back soon-ish.
Old 07-04-2023 | 10:22 PM
Patrick3000's Avatar
Patrick3000
Be well.
DSC controller is the answer
Old 07-04-2023 | 10:24 PM
Patrick3000
duplicate
Old 07-05-2023 | 01:42 AM
sabotaged's Avatar
sabotaged
Originally Posted by bajabluejay
My 997.2 C2S came with KW V3 coilovers, but the car originally came with Sport PASM, option P17, which comes with the I030/M030 Sport Suspension option. I'm looking to go back to SPASM spec for use with the DSC Controller and lower spring rates. The B16 main linear springs are 289 lb/in FR and 637 lb/in RR - similar to a 997.2 GT3 at 280 lb/in FR and 657 lb/in RR. Along with the KW V3, the B16 are too stiff for my goals with this car. 997.2 I030 springs are linear 205 lb/in FR and progressive 371-543 lb/in RR. Source.
Anyone know the spring rates on 997.2 eibach pro kit? I'm curious how they differ from B16 as I was thinking B16 would be my upgrade path -- but I don't want to sacrifice much comfort. Currently have eibach pro kit + DSC.
Old 07-05-2023 | 10:54 AM
bajabluejay's Avatar
bajabluejay
At least based on the spreadsheet I was referencing, progressive 109-194 lb/in FR and progressive 297-514 lb/in RR. The max rates then are closer to Sport spring rates than B16/GT3 rates.
Old 07-05-2023 | 01:26 PM
oalvarez's Avatar
oalvarez
Originally Posted by stiles_s
curious: did you go with the standard b6 or the damptronic? Can you say more about the ride? Please keep us posted regarding the experience of going from b6 to the b16!
Went with B6 Damptronic units....aside from the ride feeling more "firm" than previous (and less body roll), I tend to feel the difference on the compression stroke versus that of rebound. Imperfections in the road are much more felt, more pronounced "thunks" if you will when crossing over a pothole of sorts. I will definitely provide an update after the B16s are installed.
Old 07-05-2023 | 04:52 PM
bajabluejay
super interesting. This was bilstein USA you were communicating with? I also think the internal bumpstops on the b6 and b8 are tuned to assume a certain spring length as well. The spasm springs land somewhere in the middle between the oe standard springs and a typical lowering spring.
Correct. Response came from Joseph Smith - Technical & Warranty Support Expert / Team Lead per email sig.
Old 08-16-2024 | 01:00 AM
jgalp's Avatar
jgalp
any update with the B16 installed? Thank you!
Quick Reply: 997.2 factory sports suspension guru?
