Level sensor
Level sensor
Are the 2 level sensors 997 631 121 00 viewable on Durametric? How can they be calibrated. These are located on the control arms, drivers front and drivers rear.
Trying to diagnose a leveling issue, but looking for further knowledge. hate replacing parts without proper testing.
Thanks in advance
Thanks in advance
Are you referring to the headlight beam? I'm not sure about the sensors being on durametric, but when my lights were out of alignment/adjustment (I bought the car unseen and on the1000 mile drive home I got lots of flashes), I took it to the dealer for a physical recalibration/adjustment. After that, the front control module needed resetting (but that was to fix the home function and fog lights). $100 all in and problem solved. Hope this helps.
The adjustment is actually easy with a long reach hex key but I needed the module to be coded so a visit to the dealer was necessary (and cheaper than I expected).
Mine is getting a vehicle not level error when checking the oil. 997.1 turbo. There is no other sensor on the vehicle to tell its not level. Sounds like a dealer visit is required :/
