Issue with my PCM
Issue with my PCM
So I just recently purchase my 2007 997.1 c2. First time driving at night I noticed when I turn my headlights on the PCM display goes black and starts to flicker. It works perfectly normal when the headlights are switched off. Any help is much appreciated. Thank you.
Several steps to troubleshoot. There is a dimmer aspect to the PCM when the lights are on most notably when looking at the navigation. Do you know if a former owner had an aftermarket Head Unit in? Is it only the screen that is affected or does the unit power on/off as it flickers? I would start by checking all the connectors and ensure the connector pins and sockets are set properly and clean. (Time consuming).
