997.2 Carrera "T"
997.2 Carrera "T"
Starting from a base 997.2 6spd Carrera - what modifications would you do to create your version of the "T"? - Assume money is no object but modifications should be within reason (for example - no engine swaps, no major suspension changes, no welding sunroof, etc). Backseats to be retained, as well.
Would love to hear your thoughts.
- Remove nav and replace with shelf
- Radio delete
- SW center bypass
- PSE
- RS style interior door straps
- EU RS rear glass
- Rennline pedals
- Basic sports seats (non electric)
- PCCB
- Radio delete
- SW center bypass
- PSE
- EU RS rear glass
- Rennline pedals
- PCCB
Que (01-05-2023)
A carrera T is largely a marketing exercise - more value in some dimensions without having to pay for an S.
for those that can afford a new S, it’s still arguably the better car.
so starting with a 997, turning it into a “T” doesn’t actually make much sense - you’re building towards a compromise
The following 4 users liked this post by hexagone:
The following 5 users liked this post by ATX_Native:
cbredesen (01-01-2023),
DesmoSD (01-03-2023),
dmpslc (01-01-2023),
frederickcook87 (01-08-2023),
preelude (01-03-2023)
I'd start with a focus on the touch points for the best driver experience - that is half of what the T is all about (at least that's how I read it).
Numeric pedals
Shifter enhancement - SS, Numeric, FF, whatever
Shift **** of your preference
Colored belts over door straps (easier, and I'm a sucker for red belts)
Then handling performance
Lowering springs or...
Coil overs for dialed ride height and corner balancing
Lightest wheels you can find/afford
I like some of the other creature comforts (radio, ventilated seats...) so I wouldn't go that far. The link above for weight savings is a great menu to choose from...
Numeric pedals
Rig.Stunts (01-03-2023)
I've done a bit of lightening on my 997.2 Carrera, including:
- Center muffler delete and replacement with a SW bypass (~15lbs saved if you believe the marketing)
- Stock wheels replaced with lighter Apex flow forged wheels (~4lbs saved per wheel, or ~15lbs total, again if you believe the marketing)
- Manual 4-way seats (~40lbs saved according to the internet)
- "Lightweight" battery (Odyessy, Braille, Optima). Still a lead acid, just a slightly smaller 60 AMP battery vs. the standard 80 AMP battery (~10lbs saved according to the internet)
All in all, I hope that I've taken out 100lbs give or take. My brain has tricked itself into thinking that I can feel a difference . I've also done a few other things to make the car feel more driver centric such as Rennline pedals, a Function First weighted shift ****, Function First semi, semi solid engine mounts, and Fister side mufflers. Overall I'm pretty happy with the car and think it gets pretty close to the Carrera T idea (a trivially lighter Carrera with some minor performance, touchpoint, and noise enhancements).
Hope this helps
Hope this helps
Starting from a base 997.2 6spd Carrera - what modifications would you do to create your version of the "T"? - Assume money is no object but modifications should be within reason (for example - no engine swaps, no major suspension changes, no welding sunroof, etc)...
Karl.
What a really cool idea. Some good suggestions in the thread so far. My thoughts
- Delete Rear Seats
- Manual Seats or GT2 Buckets
- Upgraded Suspension
- LSD
- Euro Bumper and Euro Crash Bar
- Upgraded/lighter Exhaust
- Upgraded/lighter Wheels in Titanium Grey
- RS Door Strap
- Lighter Battery
- 911 T Style Decals in Titanium Grey
- Mirrors in in Titanium Grey
- 911 badging in Titanium Grey
Que (01-05-2023)
I'm probably showing my ignorance about the base Carrera because I am not sure you could buy one with these options, but if I were to build a 997 T (I wouldn't), I would start with a car that has a manual, LSD, Sport Chrono, and PSE. Then add/mod the following:
Check out the build thread for preelude (https://rennlist.com/forums/997-foru...ty-photos.html). His build is there in practice if not spirit.
- carbon bucket seats. Each seat is 37 lbs. Not sure what manual sports seats weigh but I suspect they are heavier. Plus, they are more supportive and look great.
- lowering springs for optics and lower CoG, better handling.
- center muffler bypass
- BBS LMs for lower weight (or any lighter wheels)
- performance tires
- Numeric shifter and weighted shift ****
- GT3/Sport steering wheel
- GT3 LCAs
- bigger rear sway bar
- any other weight savings you can find/tolerate
FYI - you know that BBS LMs are boat anchors, right? In 19" diameter ranging from ~ 23 to 27 lb
Heck, even E88s which I love and ran on my car I make no false pretenses about - they are heavy too for what they are.
I get the spirit of the thread, but I'm having a jovial time thinking any of you can discern 100-200lb of less weight? I certainly didn't feel it on the track with a passenger, and especially wouldn't on the street. And shedding 200lb from a stock car is a tall order unless you're stripping the interior entirely.
Again, all marketing. That even a Cayenne GT coupe has a "light weight" option is comical. Call it a stripped out "essential" version of the car in a "T" spec, sure. But let's admit that the driving outcome is barely improved by weight alone.
I actually don't understand how you can't feel 100 or 200 lbs of weight? Even 50 lbs, I can feel the difference in a 997. I'm either overly sensitive or you are numb. This isn't track stuff either... just street driving.
[/list]
This is very likely because you aren't using the very latest N148373646646648783883646486464 Porsche rated tire.
