Door Mirror tilt return fix.
….mirror doesn’t return to ‘normal’ view after Drive is selected.
The mirror selector is set to ‘Left’ for my RHD passenger side and tilts down as expected when in Reverse. When Drive is selected it’s meant to return to ‘normal’ view but doesn’t! This is why I swapped the motor from my drivers door mirror as I believe they’re the same motor. It worked once.
mall very odd…!
mall very odd…!
Battery died - door mirror reverse tilt function has returned!
Following my earlier thread, after swapping my right hand mirror motor for the left unit which worked just once, my car’s battery drained whilst I was away (should have left it trickle charging) but when it was fully charged the passenger mirror now behaves correctly and returns to its normal position after tilting down in reverse gear. Rebooting the circuit worked wonders!
