Clutch pedal Squeak!
Old Jun 21, 2022 | 05:05 PM
mumintrollet's Avatar
mumintrollet
Default Clutch pedal Squeak!
Recently changed my clutch, and now this annoying squeak.
Can't figure out where it's coming from.
See video.
Old Jul 4, 2022 | 03:27 PM
mumintrollet
Here is the clutch master cylinder from inside the frunk area, should I replace the master cylinder? Is there any DIY?
File Type: mov
Old Jul 4, 2022 | 06:53 PM
TerrestrialFlyte's Avatar
TerrestrialFlyte
Somebody please help, because this would absolutely drive my up the f@&$ing wall. And with my kind of luck I’ll be next so……
Old Jul 4, 2022 | 09:23 PM
Ailerons's Avatar
Ailerons
I had that same damn squeak on my 996 10 years ago. It developed a couple of months before I sold it and I never figured out what the cause was.
Old Jul 5, 2022 | 01:41 AM
mumintrollet
that doesn’t sound good. Must be away to sort it out, I believe it’s coming from the master cylinder, please help me out if you are familiar with noise.
Old Jul 5, 2022 | 10:27 AM
Ohio Performance's Avatar
Ohio Performance
Basic Sponsor
Have you tried bleeding your clutch line?
High Temp Caliper Rebuild Kits For Brembo Calipers; Caliper Pistons
Ohio Clothing
www.ohioperformancesolutions.com
2007 C4S F77 Aerokit / 2004 E46 M3 / 2018 M3 comp
Old Jul 6, 2022 | 01:37 AM
Tyler Rose's Avatar
Tyler Rose
Not sure if you have a .1 with a dedicated slave bleeder or a .2 with a recirculating slave, but have you performed a brake fluid flush lately? If so, what fluid? This can happen when non-low viscosity fluids are used.
Old Jul 6, 2022 | 01:47 AM
mumintrollet
Thank you guys, yes I believe there could be something with the brake fluid or bleeding the system. The car have been on a large maintenance service and clutch change. I believe the brake fluid is some kind of “race” version.
Old Jul 6, 2022 | 01:51 AM
Tyler Rose's Avatar
Tyler Rose
No problem.
If you do some searching, there are a number of instances with 997s and 991s running super blue/ATE 200 and having this issue.
It can be remedied with a fluid flush using an LV (low viscosity) labeled brake fluid of your preferred type. This is available from Porsche, Pentosin, ATE, etc.
If you have a 997.2, be sure to actuate the clutch to pedal “flush” the fluid since there is no bleeder on the slave.
Old Jul 7, 2022 | 03:47 PM
mumintrollet
I have a gen 2 GT3 and unfortunately not familiar with the bleeding process, is there an easy DIY?
