Question RE: Rear Deck Fan - Paranoid or ?
Greetings,
Recently (through reading some posts about our rear deck fan), I noticed that when I start my car and get out to check the rear deck, the fan spins after only about 1 minute or so after the engine is started. I know its normal for the fan to run time to time when the engine is being used on the road AND I know it runs after you kill the engine after a spirited drive session.
My water and oil temps seem fine and the coolant is the middle of Max and Min.
Is this normal? I never noticed it because I usually drive off after starting the engine and not checking the rear deck fan. Garage temp was 84 degrees F today.
Thanks for any responses.
Greeeaat ...not sure on the engine bay temp senor, no dash lights. I'm gonna hook up a code reader, but nothing out of the normal as for operation. If you know where the engine bay temp sensor is I would greatly appreciate the location. I read that you can check said sensor if it's not sitting right with a mirror and flashlight but no location information was provided.
It’s on the right side of the engine bay, sitting down between the intakes for cylinders 4 and 5 (the two closest to the rear of the car). Here’s a crappy pic of where it should be mounted. I went hunting for mine earlier tonight after some fan issues, and found it missing its grommet and laying down on the engine. It’s zip-tied up high now until the new grommet gets here.
thunder911 (06-08-2022)
I've heard either the grommet is missing or the sensor laying on the engine (like yours) triggering the fan. I'm hoping that's my issue as well. I probably have to take my car in for service soon but delaying the inevitable HAHA.
