Stone guard removal = Fun? No!!
#31
#32
It seems to be much "softer" than the other painted areas, probably to reduce stone ships.
Easy solution, use plastic scrapers and scrape UP from that parting line.
It's not that difficult.
#33
From: Bellevue, WA; '18 Macan S, '10 997S, SPASM, 6spd
#35
To anyone looking to do this I recommend a rubber eraser wheel with a cordless drill.
Honestly, made the job of removing them take 5 minutes per side after spending an hour picking and scraping with a plastic knife.
No risk of pulling paint or scratching the finish.
#36
Great tip. And I'm SURE I could figure out how to melt paint with that thing.
#37
After reading some of the nightmare stories about the stone guard removal I took it as a challenge to
see if I could replace mine without too much drama. I've removed PPF before, but not the stone guards
on my 2011 997.2.
Previously I had ordered black guards off of E-Bay and had applied those over the clears. The bonus being that
I was able to use the backing for the black guards as a template to trace and cut new clear guards
I've had the black guards on for a while, but thought it was time for a change.
I did invest in a Bissel Power Shot steam gun ($40.00 from Amazon), since my old personal clothing steamer
had gave up the ghost. While I also have a heat gun, the steam gun was money well spent.
After freeing up the top edge of the guard I was careful to pull up and away from attached material at a shallow angle.
It took a little muscle to pull and stretch the material, but I was able to remove the first guard in six minutes and the second in under five.
Both came off in one piece and there was zero adhesive left on the car. While my clear guards had been on the car since new,
they were just a little yellowed, not cracked or crazed.
With the proper tools and technique, this is not a job to be dreaded as long as your guards are in halfway decent shape.
on my 2011 997.2.
#38
From: Williamsburg, Virginia by way of Garden City, New York
My '05 guards were really yellowed, and I entrusted our local detail shop (Reflections Detailing in Williamsburg, Va) to remove them. Eric spent an entire day using steam and an eraser to get them off. I still haven't decided if I'm going to replace them given what he went through...
#39
If it were me, I'd definitely replace them since the rear quarters are susceptible to chipping (front wheels toss debris back onto the wider quarters).
However, I'd likely look to replace them in about five years like someone posted earlier. This will make removal easier the next go 'round.
