Correct Wheel Torque
+1, ridiculous. With 130Nm/96ft lbs you are 100% on the safe side, no matter how colourful the screw is. Apparently they have changed the manual, mine doesn't say that at all. Exceptions are connections with spacers and, of course, central locks (!).
Hilarious, everyone bangs on about freedom and being able to steer one's own destiny.
Suddenly, given a free choice between 130Nm and 160Nm they all loose their ****?
Workshop manual 997:
1. Before fitting the wheel onto the wheel hub, grease the centring surface on the wheel hub with a very thin layer of Optimoly TA (aluminium paste); not thread!
2. Always observe the prescribed tightening torque of 130 Nm (96 ft*lb). Use 19mm socket an no impact wrench for tightening.
That's in contradiction to what the 997.2 owner's manual says:
It seems the owners manuals vary massively! They are full of quirks like mine says the car can stream music via Bluetooth which it can't. It's got about aux input volume where another doesn't.
There clearly is a lot of variation.
Hello All,
What is the correct torque setting for wheel bolts on a 997.2? I seem to find conflicting information everywhere from 96nm - 160nm and everything in between.
Showbox jiofi.local.html tplinklogin
Does anyone know the correct value please?
Many thanks!
Many thanks!
Has anyone's wheels fell off at any of the specs mentioned? Your fine regardless. When in doubt, follow your manual.
I personally use 100 on any vehicle. No reason besides it's easy to remember and it works.
