Rennkit BTR-3 Bluetooth experience
All, I've read all the threads I can find on Rennkit's BTR-3 bluetooth system for PCM2.1 for 997, but before I pull the trigger on purchasing, I wanted to understand the 12v power requirements.
Some threads say constant 12v is required, some say it can be powered by switched/acc. I obviously don't want to end up re-pairing my phone every time I crank up the car, etc.
Has anyone installed this on their 997 and can you confirm which way you powered it?
I'm hoping that if constant 12v is required that the unit will self-power down or something rather than drain the battery.
Thanks in advance.
Thanks in advance.
RennKit-Dave (08-23-2022)
I just installed the BTR-3 in mine. I back pinned the harness off the PCM2.1 and used that as the power supply source, its a constant 12V source and I haven't had any drainage issues. I also installed the microphone in the steering column where the factory one would go, but it doesn't work to well in that location. While driving there is a lot of road noise and you have to pretty much yell for anyone to hear you. Hope this helped some.
RennKit-Dave (01-31-2022)
This looks like a Rennkit-badged version of the same one I installed a few weeks ago (mine was the Mr 12v brand).
- It does require a constant power source
- The microphone works well if installed at the top of the windshield, to the right of the driver's sun visor (assuming a left hand drive car).
I'm considering the BTR-3 (or would it be BTR-3PM???) for my 987.1 CS that has factory NAV, BOSE & phone module. Suggestions, recommendations, comments?
I trust it's more than a FM modulator.
Basic Sponsor
Dave
Rennkit
djcooper@rennkit.com
http://rennkit.com/
Rennkit
http://rennkit.com/
- Patented eRam Kit™ for 996/997 Turbo & Carrera GT wings
- Cal*Cool™ - brake cooling 996/997 / Bluetooth Retrofit Kit™ for 1998-2011 cars / Wing Extenders™ 987 Cayman / 997 Turbo
- AUTO-BLiP for MT / Function F1RST Shift ***** / Girodisc 2-piece rotors / OS Giken LSD / Phenix suspension / Zunsport grills / 997/987 switches/PCM ***** / Border Coilovers
