Transmission Mounts?
Old 12-14-2021, 12:04 PM
BHMav8r
BHMav8r's Avatar
Received 2,744 Likes on 1,737 Posts
Default Transmission Mounts?
Wondering if transmission mounts are necessary when replacing motor mounts?
They are not too expensive but the tool to press the bracket on is $450 - Is it necessary?
2005 74,000 miles.
TIA
Sam-g (12-14-2021)
Old 12-14-2021, 12:17 PM
mcfisticuffs
mcfisticuffs's Avatar
You will need a press of some kind to get the new mounts in. You can usually remove the old one by cutting it (I have not done this.)
Alternatively, you can simply install some transmission mount inserts (see Function First) to reinforce the original transmission mount without needing to replace them, but these, even at their softest, cause a marked increase in NVH.
Old 12-14-2021, 12:20 PM
Emc2design
Basic Site Sponsor
Emc2design's Avatar
2005 74,000 miles.
TIA
@BHMav8r go this route first unless your existing mount is totally compromised: https://rennlist.com/forums/997-foru...r-997-2-a.html
Visit us online https://emc2design.com
By Porsche enthusiasts
For Porsche enthusiasts
jchapura (12-15-2021)
Old 12-14-2021, 01:06 PM
BHMav8r
BHMav8r's Avatar
Wow - very interesting. I will look into this. Thanks!
PS - just ordered a set.
Emc2design (12-14-2021)
Old 12-14-2021, 07:37 PM
frybear
frybear's Avatar
I just installed the function first transmission mount inserts - orange/softest. Very little if any NVH, so don't let that be a worry.
Spike Speakus (03-10-2023)
Old 12-14-2021, 08:11 PM
Wayne Smith
Wayne Smith's Avatar
Received 1,195 Likes on 762 Posts
I went with black (race) mounts in my 2010 C4S PDK with 145K miles. Also went with the hardest motor mounts. NVH was not substantial. These are sports cars!!!
IMHO the motor mounts were more significant for handling (reducing motion at the rear).
frybear (12-14-2021)
Old 12-15-2021, 08:29 AM
Butzi 997
Butzi 997's Avatar
The NVH with FF's orange inserts in my car is only noticeable to a minor degree while idling at a stop light.
Old 12-16-2021, 12:55 AM
9.1.1's Avatar
I used the insert from powerflex (yellow ones). Really easy to install and it works 👍 awesome
Old 12-16-2021, 10:47 AM
BHMav8r
BHMav8r's Avatar
Gotta love Rennlist !
frybear (12-16-2021)
Old 12-16-2021, 10:58 AM
frybear
frybear's Avatar
Rennlist and youtube get me where I need to be!
BHMav8r (12-16-2021)
Old 12-16-2021, 02:17 PM
SilCab
SilCab's Avatar
I like the Cantrell Motorsport transmission mounts.
They're super-high quality and installed easy with a Harbor Freight ball joint/bearing press.
Last edited by SilCab; 12-16-2021 at 02:28 PM. Reason: edited to add link to video
Skrizzo (06-18-2024)
Old 12-17-2021, 02:18 AM
fayraree
fayraree's Avatar
agreed
Old 12-18-2021, 02:25 AM
kdu
kdu's Avatar
How do you like them? I'm debating between the FF and the Powerflex, wasn't sure if the additional cost of the FF is worth it?
Old 03-09-2023, 02:31 PM
911desire
911desire's Avatar
I wonder about this also. Has anyone compared the FF orange and the powerflex yellow? Are there any OEM inserts available?
I have a 997.2 C2S 6sp and wonder if either would be better to keep the NVH to a minimum.
thanks.
Old 03-09-2023, 03:03 PM
BHMav8r
BHMav8r's Avatar
Still have not installed mine. Really need a screw jack and/or a helper to jack the tranny at just the right height the put the bolts back in.
Quick Reply: Transmission Mounts?
