Windshield Washer
the windshield washer motor on my 2006 911 Carrara does not run. I thought it may be a fuse but there is no fuse shown on my fuse listing supplied with the car.. I've read it over but still haven't found the fuse. Can someone enlighten me, Thanks in advance for your input.
Probably your washer pump. You need to remove the driver's side inner fender liner and pull the tank. There's a few videos online how to do this. Check the pump by applying battery voltage. I just had mine crap out on my 06. Got the part from Napa for 25 vs $80 for the Porsche part. Perfect fit and it's just a small impeller pump.
propchef (10-18-2021)
Chalkboss (10-18-2021)
