Signal light error
I just got the car home this morning after 1400kms.. The owner did mention this issue but it really bugged me on the drive home.. Occasionally when I turn on the left signal it will give me an error on the dash. It will clear eventually but comes back. I find it happened more with the light press (change lanes) vs long press (actually turning). I noticed the flasher in the dash goess fast but it appears both front and rear are flashing at the normal rate. I'm going to hopefully have a look at the plugs sand wiring and clean it all up..
Just curious if I should be looking into something else or if this is a common issue?
Thanks guys
Edit: I should add it is a 2009 tt 6 speed. Also I've tried searching but on my phone it doesn't appear to work very well
Thanks guys
