I have found them to be a royal pain in the *** on all but one car, my 2016 BMW Z4. Glad to not have them on my 06 C4S. I regularly check pressures before heading out.
2006 C4S
Is there a way to tell if i have/should have TPMS without playing with the computer? the car is in storage and i need to order tires for when it comes out. Do build sheets include this info and if so, how do i get one?
such is one of the challenges faced by a newbie. thank you for any input.
2006 C4S
you should see the tpms info when you start the car and/or when scrolling thru the menus on your instrument cluster. otherwise you will need a durametric pro/foxwell 530 to scan through your modules ... if you have tpms a 'tpms' module will show up.
i believe tpms oem factory issue by law was MY 2007. the technology was out before that but as an option only.
to the OP, there are various standalone aftermarket tpms adapters, but they look like overtly tacky/large tire valve caps (to house the tire pressure electronics)
The only oem looking tpms sensors I have seen, are the ones available as a USB add-on that is connected to any android based deck. These type of tpms sensors look like the factory ones where the TPMS electronics are hidden by the tires themselves - and can only be installed when fitting the tire to the rim. I have these for my 2005 mated to my android pcm as my car didnt have oem tpms.
I did buy a standalone tpms system but sold them right away - the tire caps look so large + silly.
TPMS was always an option prior to the 07 MY cars. I ordered them for my 06. Very glad to have them. TPs are critical on such low profile tires. To retrofit them is not an inexpensive proposition. Keep in mind that the wiring harness is custom to each car due to options and adding something like that is possible but pricy down stream.
