Ignition Key sticking issue AGAIN !!!!!!
Old Aug 2, 2021 | 02:55 PM
Idoktr's Avatar
Idoktr
Default Ignition Key sticking issue AGAIN !!!!!!
In prev post had ignition key stuck. Replaced battery in key fob, replaced car battery and replaced ignition module. Any suggestions????????
Old Aug 2, 2021 | 03:14 PM
Skwerl's Avatar
Skwerl
Someone had a stuck key in the Turbo forum the other day, would this help?
https://rennlist.com/forums/997-turb...stuck-key.html
Old Aug 2, 2021 | 03:28 PM
Idoktr's Avatar
Idoktr
I already know how to remove the key. I keep a paperclip in the ashtray. Just need to know how to fix the issue.......thanks
Old Aug 2, 2021 | 04:36 PM
997.2GTS's Avatar
997.2GTS
Just to confirm, you replaced the ignition switch module in the dash (what you stick the key in)? Was it the newer module (has a different number suffix) than original?
Old Aug 2, 2021 | 04:37 PM
Idoktr's Avatar
Idoktr
Newer model. Cannot find the old model anywhere...........
Old Aug 2, 2021 | 05:39 PM
997.2GTS's Avatar
997.2GTS
That's a good thing, as the older model made in Australia has issues, and I was hoping you had the newer one (made in Spain). That was what solved my issue. Beyond this, I have no idea, unless you have been very unlucky and the replacement switch has also failed.
Old Aug 14, 2021 | 07:24 AM
Idoktr's Avatar
Idoktr
anyone else????????? this is driving me crazy.
