Cab Top Help Please- micro switch issue
Hi all. I am at a complete loss and I am hoping someone here can guide me. I have a 2005 997 cabriolet and when I am opening the top the clamshell shakes when closing and will not close. The fabric top seems to work fine and opens and closes normally but when it comes to the clamshell closing it shakes. (When closing, the clamshell works fine)
The top has almost been completely redone at this point. The rams were rebuilt by Craig on here and a new fabric top was just installed but the clamshell still doesn’t close right when I am putting the top down.
I finally booked in to the Porsche dealer today and after a lot of fiddling with the computer they said it is one of the micro switches. It works perfectly when being ran with no micro switches but when the switches are engaged it seems as though it gets caught and opens again.
Sorry if this is a long read but my question is how would I work out which micro switch it is? The top functions perfectly when closing. The rear deck shakes when open and after about ten tries will allow the deck to seat and the top to open fully.
thank you!!!!
I also have a video attached
thank you!!!!
Last edited by ph2426; 03-02-2021 at 04:03 PM. Reason: changing deck lid wording to clamshell
You might check out the following thread - (and specifically post # 5 within that thread...)
https://rennlist.com/forums/997-foru...-position.html
Hope you're successful in resolving the issue.
Perhaps someone with more diagnostic skills can answer that question. I cannot.
If it is a microswitch problem, it appears from the diagram in the link above that there are only two likely culprits:
# 7 and # 9.
I would ask your dealer what the function of component #8 in the diagram is: (Potentiometer, convertible-top compartment lid interrogation).
From your video, it looks like the controller senses a problem with the left and right flaps closing properly and the lid closing process is prevented (and then reinitiated) because of that.
# 7 and # 9.
Thank you. I am not sure the dealer will help. They said they needed to check all the micro switches and it would be a starting cost of $500 and then up from there. I didn’t get the impression I could call and get advice unfortunately.
If you're fairly mechanically adept, you could probably replace all or most of the microswitches for less than $500.
If it was me, I would rule out the microswitches tied to the front latch mechanism (front of the top that connects to the windshield header.) The number of microswitches involved in the closing process seems to be fairly limited.
Is there an independent Porsche shop near you that could provide some assistance?
Yes that is true. I was trying to find the micro switches to buy them but couldn’t find the part numbers. I removed the rear carpet cover and think I can see at least one micro switch but not sure where the one is for the flaps. I guess I could just buy those two and change them and see.
You might want to contact Suncoast Porsche parts with your VIN number. Let them know what you're looking for. They most likely will prepare a quote for you with the various microswitches and associated prices.
An update... Perhaps you could add some feedback?
The micro switches all seem to be functioning properly but the drivers side ram is still leaking. I was not aware of this before and it had just been rebuilt. It looks as though when the top is pulled down tight right before the clamshell closes the top releases a bit. When I hold the top down the clamshell closes perfectly. Could this now be due to the ram still leaking?
mayt007 (12-09-2021)
Good evening. Yes, we eventually worked out what was wrong. The pentiometer (not sure the spelling) behind the drivers side rear speaker needed to be adjusted. Once we adjusted that slightly it started to work fine. It was a lot of trail and error though.
sierra73 (06-22-2023)
Can you tell me how you got the right rear interior panel off ?
It sounds like a sticky microswitch. Microswitches tend to have silicon grease in them to keep them lubricated. As the grease ages it can cause the switches to stick. That might explain why it works in warmer temps.
Ideally, you could remove the microswitches, disassemble them, spray them out with electronics cleaner. Re-lubricate and reinstall.
You might be able to get away with spraying them with electronics cleaner; and skipping the disassembly.
