HPDE Question
HPDE Question
I have a 997.2 and it is a manual. For the fastest in cornering. When should I completely let out the clutch and engage the gear whatever it is. I have heard many different answers and I am not sure which is correct. Thanks in advance.
For your purpose, always complete gear changes prior to turning. Stay on power through the turn, and increase as you exit. You will want to brake in a straight line before entering the turn, using a proper heel-toe technique to downshift, then immediately switch to maintenance throttle as you enter the turn and all the way to the apex. Once you reach the apex, smoothly roll on the throttle while unwinding the steering wheel. The 911 has tremendous launch power due to 65% of the weight being over the rear, power wheels! Hope this answers your question!
The following 4 users liked this post by ThomasCarreraGTS:
As mentioned above complete the gear change before turn in. Definitely off the clutch, I have had quite a few students who want to wait till mid corner to come off the clutch. The idea is to keep the car as balanced as possible
So the clutch should be completely out before I even start turning the steering wheel? I should be in the gear that I will need coming out of the corner.
Since I am off the clutch could I brake with my left foot if I can’t heel toe smoothly?
Currently I am right there with you students getting off the clutch half way around the corner. I have some habits to change.
The pedals are close enough to not need heel to toe. I use the following method and to me it’s more efficient.
The following 6 users liked this post by atihun:
8KaboveMSL (02-24-2021),
997.2GTS (02-24-2021),
DesmoSD (02-24-2021),
dmpslc (02-24-2021),
Liste-Renn (02-25-2021),
and 1 others liked this post.
As others have almost said, the throttle pedal is critical to keeping the car balanced and transferring weight where it is needed for grip while you are cornering. Car starting to understeer? Back off the throttle a bit and let the engine slow the car and transfer weigh to the front tires. Rear end loose or oversteer? Apply some throttle to shift the weight back to the rear tires. The faster you go, the more subtle these actions are, and the more important they become to staying on the black stuff.
If you aren't in gear, you have no way to regulate your weight/grip.
As an instructor friend is fond of saying, " Clutch in is no wheel drive."
Thank you so much for clearing this up. I wanted to really get into events last year and then Covid happened. There have been events, but they have not allowed instructors in the car so I have not gone as I do not want to undo bad habits.
Heel and right side of your right foot on the gas, and tip of your big toe and left side of your right foot firmly on the brake. While applying maximum brake pressure, roll your foot to the right, blipping the throttle pedal. You wont want to slip off the brake pedal if you're hauling down from high speed and coming up on a turn.
The YouTube video Atihun shared is a good one. Also, before you go to a track day event, there are some things you’ll need to know and bring. I made this video to help new track rats!
HOW TO BECOME A RACE CAR DRIVER (How to get a racing license)
doclouie (02-24-2021)
ThomasCarreraGTS (02-24-2021)
I’ll be instructing at COTA again March 27 and 28. Come on out and ill take you for hot laps in my GTS. If you end up signing up for the event, I'm also happy to instruct you. And we are allowed to ride in your car. I can also show you what your car can do!
The following 3 users liked this post by ThomasCarreraGTS:
I would love that, but Edge Addict’s lowest level is yellow for this event. Which I ran in the yellow group in the afternoon last time I was at COTA and was towards the back of the group, but there were 3-4 cars behind me. They want 3+ track days and I have like 1+. Maybe I will reach out to Karen and see what I can do.
