Engine Mount
Should I replace the engine mount on my 2005 911 with 18K miles with an aftermarket mount. And will it cause unwanted vibrations?
2009 C2S 167K miles
Time may wear them out but I doubt it... if it did, you would see leakage. They have to be pretty tough not only carrying the weight of the engine, but all the shift and leaps we crazy knuckleheads put on them. Given you don't drive the car, if there is no leakage, IMO, then there is no wear. Go drive it.
Peace
Bruce in Philly
Peace
Bruce in Philly
Check your exhaust tips and see if they’re sagging.
I recommend Function First engine mounts. With the FF mounts, I experienced less vibrations than the original worn out OEM mounts. YMMV of course.
2009 C2S 167K miles
Peace
Bruce in Philly
Peace
Bruce in Philly
