Ummm Lock/Alarm question
So I just picked up a 2006 carrera 4s yesterday and unfortunately it came with 1 remote. Also only the hood release button works on it, the lock unlock button does not. I plan on getting other keys, however I used the key to lock the car and just unlocked it in my garage opened the door and the alarm sounds and hazards blink, the sounds stop after about 30 secs but hazards blink until I relock the door. So I unlock the door again manually with key and notice the little red light is still blinking.....
Am I doing something wrong, i figured a manual key unlock would be sufficient to deactivate the alarm or am I fu*ked?
When you unlock the car manually with the key you need to insert the key into the ignition quickly. If the car doesn’t detect the transponder inside of it, the alarm will sound assuming your car was pick-locked.
Thank you so much! such bs that keys are about $350 from dealership.... #PorscheLife
https://www.keysinthepost.com/products/
However and as Vethen states, you'll still need to have it programmed by the dealer or someone with a PIWIS.
