Yaw sensor kill switch Sport mode malfuntion
Hey guys, I recently installed a kill switch for my yaw sensor in order to disable traction and stability control. I attached a switch to the ground wire in order to disable it. When the yaw sensor is disabled I'm getting an error saying sport mode malfunction. When I called my local race shop they say they don't have issues with sport mode. Anybody having this issue or know a way to solve it?
1) This shop doesn't find sport mode an issue in general
-or-
2) This shop has installed the same switch in a 997.2 Carrera, and they don't see this error?
Since the yaw sensor is an integral part of the stability control system, it's not surprising there are diagnostics to detect issues in that circuit.
Are you saying...
-or-
Are you saying...
-or-
I'm tempted to do this on my 997.2 as well. Did you follow the cayman's switch installation DIY? Is the location of the sensor and wiring similar to the cayman?
How do you like it when it's fully off?
The PASM module uses accelerometer inputs to manage damper settings. So without those inputs (or at least one of the axes in this case) it's not going to work. Hence, it makes sense you would get this error.
Liste-Renn (01-28-2022)
i was thinking about getting lsd (mine is pdk and there are very limited option of lsd for 997.2 pdk car), but then think maybe I should try this mod first... but I guess from your experience I might as well just do both...
You cannot disable stability management on a PDK car as the PDK needs that information. Get the LSD instead (Wavetrac, Giken) with the appropriate diff cooler.
i probably want to get a LSD regardless. just a shame that Giken and Guard don't have one for 997 PDK c2s (I checked with them). so choices really are just Wavetrac, or a shop called Deman in New Jersey they can custom make one...
Basic Sponsor
@Frank 993 C4S wait... so what would happen if I pull the yaw sensor of my PDK car?
We have the BEST LSD for 997.2, 987.2. 981, 991 PDK cars that came from the factory WITHOUT LSD.
These are better than anything on the market and super robust, 6 different ramp angle combination adjustable.
![](https://cimg4.ibsrv.net/gimg/rennlist.com-vbulletin/960x960/deman_motorsport_pdk_lsd_1f4dee126bb0d2317bd4f8ce00a5cc8bcba5264b_5da2b4952de9307930480e0cef5a3524ea78025d.jpeg)
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Porsche Sales & Service
Porsche Race services and parts
www.DeManMotorsport.com
2016 GT4-R
Rick DeMan
DeMan Motorsport
Upper Nyack, NY
845 727 3070
Basic Sponsor
@Rick DeMan Is there some form of warranty that comes with the LSD? What are the roughly expected road/track miles the LSD will last before needing a rebuild? Thanks.
Life is dependent on use, these are the most robust units ever made for this application. They are warrantied against defects for 1 year.
