Numeric Shift Cable Routing Advice Needed
Old Aug 31, 2020 | 11:25 PM
RC713's Avatar
RC713
Default Numeric Shift Cable Routing Advice Needed
Dropped my 2008 997 Cabriolet S off today at my local independent shop for an oil change and Numeric Shifter and Cables install. The shop called me to ask if I had taken out any instructions from the box when I opened it. I had not. My mechanic, who is solid, complete faith, wanted to make sure that he was routing the cables in the best way, due to their proximity to a main power line located in essentially the same place but with less space due to the thicker cables and cable insulation tubing. Called Numeric but being on PST, they had left for the day. I left them a voicemail and will follow up with them tomorrow, but thought it would be worth it to ask this sage crew. Any advice appreciated, pics even more so. As always, thanks in advance.
Old Sep 1, 2020 | 12:11 AM
415CPA's Avatar
415CPA
Instructions can be found on their site.
https://www.numericracing.com/theme/...on-guide-1.pdf
https://www.numericracing.com/theme/...stall-2018.pdf
Old Sep 1, 2020 | 01:57 AM
RC713's Avatar
RC713
Thanks 415CPA, saw the first one, good info but doesn’t show routing. Hadn’t seen the second one but that’s a 986/987 install, not a 997, good pics for that install though. Appreciate you posting them.
Old Sep 1, 2020 | 02:02 AM
415CPA's Avatar
415CPA
For 997
https://www.numericracing.com/theme/...ll-7-11-18.pdf
