Coolant Flush
@Bruce In Philly, just a heads up that neither of your links were working for me. The top one went to eBay and jack stands, and the bottom one to Walmart with a 404.
Thx!
Bob
Thx!
Bob
Peace
Bruce in Philly
@Bruce In Philly I have the 550500 and can't complain. I run it off a cheap $150 Harbor Freight 21 gallon air compressor (you wouldn't want any less than that though - pancake compressor won't cut it), and it pulls the required vacuum quickly. The only "issue" I find with it is that the cone shaped rubber snubber that you wedge into the coolant expansion tank opening seems to shed a bit - like when you touch it with your hand, your hand gets black. Not sure what kind of rubber it is that causes that but it hasn't caused a problem and I've owned it and used it for 6 years or so now. Actually just used it two weeks ago when I did my flush. Performed flawlessly.
Peace
Bruce in Philly
It’s me. It’s not you.
1,000 apologies.
Bob
I have this compressor:
https://www.harborfreight.com/air-to...sor-61454.html
For $150, it will run air tools, coolant lift pumps, etc. It's not huge and doesn't take up much space. I miss my big 60 gallon 2-stage compressor but just don't have room for it in my current garage. This $150 compressor is great - I store it in a closet in the house and wheel it out to the garage on an as-needed basis.
